Uus autodiagnostika seade ELM327
hind 8 euri
Features:
1. Display current sensor data, including: Engine RPM, Calculated Load Value, Coolant Temperature, Fuel System Status, Vehicle Speed, Short Term Fuel Trim, Long Term Fuel Trim
2. Display current sensor data, including: Intake Manifold Pressure, Timing Advance, Intake Air Temperature, Air Flow Rate, Absolute Throttle Position, Oxygen sensor voltages/associated short term fuel trims, Fuel System status, Fuel Pressure etc.
Clear trouble codes and turn off the MIL (\"Check Engine\" light)
Operation system supports: Android Smartphones, Symbian, Microsoft (mobile phone, tablet), most computer system(except Apple system), and all these device must have Bluetooth function.
NEW Mini ELM327 V2.1 OBD2 II Bluetooth Diagnostic Car Auto Interface Scanner
Vehicle Coverage: Works on all OBD2 Vehicles.
OBD-II Protocols:
SAE J1850 PWMSAE J1850 VPW (10.4 Kbaud)
ISO 9141-2 (5 baud init, 10.4 Kbaud)
ISO14230-4 KWP (5 baud init, 10.4 Kbaud)
ISO14230-4 KWP (fast init, 10.4 Kbaud)
ISO15765-4 CAN (11bit ID, 500 Kbaud)
ISO15765-4 CAN (29bit ID, 500 Kbaud)
ISO15765-4 CAN (11bit ID, 250 Kbaud)
ISO15765-4 CAN (29bit ID, 250 Kbaud)
SAE J1850 PWM
SAE J1850 VPW
ISO 9141-2
ISO14230-4 KWP
ISO14230-4 KWP
ISO15765-4 CAN
ISO15765-4 CAN
ISO15765-4 CAN
ISO15765-4 CAN
Specifications:
Processor: ELM327 V2.1
Dimensions: about 4.7 * 2.5 * 3.1cm
Net weight:31g
Package weight:41g
Color:blue
Package includes:
1 x ELM327 Bluetooth OBD2 Scanner Tool
1 x CD
asub Tallinnas
ühendust saab PS teel tel 56791733
M: Autodiagnostika seade ELM327
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
