Müüa kasutatud, kuid heas korras D klassi võimendi Blaupunkt THA 475 PnP. Ostetud kaks aastat tagasi, kasutuses olnud ca 1 aasta. Tänu kompaktsetele mõõtmetele 285 mm x 41 mm x 160 mm lihtne paigaldada nt. esiistme alla.
Andmed:
• THA Plug-n-Play Series 4/3/2-Channel Class D Power Amplifier
• Ready For Plug&Play connection using optional adapter cables
• Conventional connection possible with attached screw terminals and Cinch inputs
• Maximum efficiency – low heat generation
• Max power into 4 ohms: 720 watts
• Max power into 4 ohms: 4 x 150 watts / 2 x 360 watts
• Max power into 2 ohms: 4 x 170 watts
• RMS power into 4 ohms with Ub = 14,4 V: 4 x 75 watts / 2 x 180 watts
• RMS power into 2 ohms with Ub = 14,4 V: 4x 85 watts
• Channels: 4/3/2
• Frequency response: 10 – 30.000 Hz
• Signal/noise ratio @ 1W/1kHz: > 78 dB/A
• Signal/noise ratio @ full power: >95 dB/A
• Total Harmonic Distortion (@ full rated power): >0,05%
• Adjustable sensitivity: 0,3 – 8 V
• Stability: 2 Ohms (4 Ohms in bridged mode)
• Variable low-pass filter: 50 – 250 Hz
• Variable high-pass filter: 10 – 250 Hz
• Inputs: 4 x Cinch/RCA, 4 x high-level via Pnp-connector with automatic turn on, 2 x Direct AUX Input 3.5mm stereo
• Outputs: 4 x speaker, 2 x line out
• Dimensions (W x H x D) : 285mm x 41mm x 160 mm
Müüdud: Võimendi Blaupunkt THA 475 PnP
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
