S80 150kw õlikulu
sanzz
S80 150kw õlikulu
PostitusPostitas sanzz » 15 Aug 2010, 21:07
Kas keegi viitsiks Vadisest s80 (1999 2,9 150kw autom.) õlikulu tabeli siia trükkida. Seal oli kirjas õlikulu erinevates olukordades.
Tänud :)
Volvo S80 2.9 150kw
Re: S80 150kw õlikulu
PostitusPostitas vanapeer » 15 Aug 2010, 23:14
Kas volvoosad.com pole?
sanzz
PostitusPostitas sanzz » 16 Aug 2010, 09:53
Manuaalides pole kirjas, sealses foorumis pole ma aga kasutaja. LIhtsalt jäi meelde, et Vadises oli, aga mul pole seda enam installitud.
Volvo S80 2.9 150kw
Vikko
PostitusPostitas Vikko » 19 Sept 2010, 23:15
Normal oil consumption
Running-in period
The oil consumption can be as much as 1 liter per 1,000 km during a running-in period of approx. 5,000 km if the engine is new or replaced (replacement of piston ring).
Driving between 5,000 and 150,000 km
Normal driving: up to 0.25 liters per 1,000 km is considered normal oil consumption.
Driving at high speed/with heavy trailer: up to 0.40 liters per 1,000 km is considered normal oil consumption.
Mountain/alpine driving: up to 0.50 liters per 1,000 km is considered normal oil consumption.
The above stated values for oil consumption can be used as guidelines if there is a suspicion that oil consumption is unusually/abnormally high.
Note! The oil consumption can be as much as the following at 150,000 km. The oil consumption can be approx. 0.35 - 0.55 liters per 1,000 km under all conditions.
S80 2,9 136MGG
sanzz
PostitusPostitas sanzz » 20 Sept 2010, 08:54
Suured tänud! :)
Volvo S80 2.9 150kw
jansatrt
PostitusPostitas jansatrt » 20 Sept 2010, 10:38
meenub ühe auto müügil ostjale vastatud , et õlikulu on umbes 1l 10000km jooksul, sellepeale kirtsutati nina ja kobiseti, et seda õlisööjat me küll ei taha
58158239
sanzz
PostitusPostitas sanzz » 20 Sept 2010, 12:09
Selle järgi teeb 10 000 peale miinimum 3,5 liitrit siis. Ma ükspäev enda autol vaatasin, et isegi peale karterituulutuse puhastamist mingi õlinire tõmmatakse sisselaske kollektorisse. Nii see õli kaobki: kuuelt silindrilt veidike õlirõngaste vahelt + mingil määral klapisääre tihendite vahelt + karteri tuulutuse kaudu.
Ma olen selle õlikuluga leppinud, ning VADIS ei valeta :).
Volvo S80 2.9 150kw
Vikko
PostitusPostitas Vikko » 21 Sept 2010, 00:11
Mina ehmatasin ka korra ära kui mingi 7000km peale õlivahetust ainult miinimum sees oli- Aga ju's peab olema...
Lisaks, seal on ikkagi kirjas, et can be... mitte, et will be, seega eks see sõltub ikka väga paljudest faktoritest..
Täna oli mu autol õlivahetus, eks siis nüüd tean ise ka täpsemalt jälgida, et palju 1000km pärast õli kadunud on:)
S80 2,9 136MGG
Kasutajad foorumit lugemas: Registreeritud kasutajaid pole ja 48 külalist
