Müüa uus tagurduskaamera
asub Tallinnas ja mujale liigub postiga
hinnaks 35 euri
ühendust saab PS teel või tel 56791733
Item Description:
Specifications of Monitor:
Screen:
- Size: 4.3 inch TFT LCD
- Resolution: 480x272
Main Features:
- With two channel input
- The monitor will start up automatically, and synchronously display the video from rearview camera when you're backing your car; the monitor will close itself after backing
- Scenes will cut to rearview camera automatically while you're backing the car and change back to the original scenes after that
With no audio input or output
Display black screen when no signal
Supports Car DVD, VCD, camera, STB, satellite receiver, and other video equipment
Menu Buttons: Brightness/ Contrast/ Hue/ Saturation
Support Language: English, Chinese, Spanish
Support Visible Area: 96mm x 54 mm
Working Temperature:
- Work: 0 to 80 degrees C
- Storage: -10 to 80 degrees C
Power supply: DC 12V / 24V
Power consumption: 2W
Material: ABC
Color: Black
Specifications of Camera:
Image Device: 1/3 Inch color CMOS
LED: 7 infrared night vision LED
Distance of Transmission: 100M (no barrier)
Resolution: 420-cable image sensor
Visual Angle: 120 degrees
Diagonal Visual Angle: 90 degrees (Vertical visual angle)
Shockproof: 6.8
Emission Frequency: 2,414MHz
Video Input: 1.0Vp-p, 75ohm
Power Supply: DC12V, 200mA
Working Temperature: -20 - 60 degrees celsius
Package Including:
1 x Monitor
1 x Power Cable
1 x User Manual
1 x Camera
1 x DC Power Cable
1 x AV Cable (19 ft)
M: Tagurduskaamera
Kuulutuse sisestamisel mõelge hoolikalt läbi, et teist ei jääks halba muljet. Moderaatoritel on õigus oma suva järgi teie postitusi siit eemaldada!
